First Window
In this section, we will create the simplest window to learn how to build our own GUI and run it on WalnutPi.
Creating a Window with Qt Designer​
  1. WalnutPi needs to be connected to an HDMI monitor, keyboard, and mouse for design, or operated via VNC remote desktop. Refer to: VNC Remote Desktop.
  2. Due to PyQt5's excellent cross-platform features, the operations in this section also apply to Windows.
Qt Designer is used to design PyQt5 windows. This section only demonstrates the basics. More detailed window settings and widget functions will be covered in later chapters.
Open Qt Designer. There are different window type options in the upper left corner. Generally, select Main Window by default, then click Create:
window1
After creation, the interface looks like the following. The functions of each area of the software are as follows:
window2
Considering that some users want to display on a 3.5-inch LCD, we can resize the window to 480x320 (WalnutPi 3.5-inch LCD resolution). Expand the geometry property in the right-side Property Editor, then adjust the width and height to 480 and 320.
window3
Drag a PushButton widget to the window.
window4
Drag a Label widget to the window.
window5
Double-click the label to modify its content. Change the content to: Hello WalnutPi.
window6
The windowTitle property can be used to change the window title bar name:
window6_1
The windowIcon property can be used to change the window's top-left icon. Interested users can modify it themselves:
window6_2
We will use this window as our first demo window. Click the menu bar Form--Preview:
window7
You can see the window we just created in the preview. This feature allows you to check whether it matches the desired effect during development.
window8
Click the menu bar File--Save or directly click the close button in the upper right corner of the new window to save the window. Name it whatever you like. Here we save it as "window.ui".
window9
  • Saving on WalnutPi
window11
At this point, the design of the first window UI file is complete.
Converting the Window UI File to a Python Code File​
We need to convert the designed window UI file into Python code so that it can be executed by the Python program on WalnutPi. This can be done directly via terminal commands:
In the terminal, navigate to the directory of the window.ui file and execute the following command. This command generates a window.py file from the window.ui file:
python -m PyQt5.uic.pyuic window.ui -o window.py
After execution, you can see the generated .py file:
window12
Opening the window.py file, you can see the generated Python code, which mainly consists of window name, position coordinates, and other attribute settings. You can modify the window or button property values, then regenerate the .py code and compare, to intuitively understand how each object is used.
# Form implementation generated from reading ui file 'window.ui'
# Created by: PyQt5 UI code generator 5.15.9
# WARNING: Any manual changes made to this file will be lost when pyuic5 is
# run again. Do not edit this file unless you know what you are doing.
MainWindow.resize(480, 250)
MainWindow.setWindowTitle(_translate("MainWindow", "WalnutPi"))
self.pushButton.setText(_translate("MainWindow", "PushButton"))
As you can see, the generated code only defines classes and functions, so it cannot be run directly. Some additional code needs to be added to display the window, which will be covered in the next section.
