System Usage
This section explains the common functions of the WalnutPi 1B Android TV system.
WalnutPi 1B has an onboard IR receiver, and can be controlled using a universal Android TV box remote control. Click to purchase >>
The blue LED will blink once when a signal is received successfully.
android_os
USB Keyboard and Mouse​
You can connect a USB wireless or wired mouse to operate the Android system. In practice, some wireless mice are not supported — the model below is supported.
android_os
After plugging in, the mouse cursor will appear on the screen. When the keyboard is triggered, the blue LED will blink once.
android_os
Bluetooth keyboard and mouse can also be used:
Language Settings​
The default language after boot is English. You can set it to Chinese or other languages using the following method.
android_os
android_os
Connecting to the Internet​
WalnutPi supports WiFi (2.4G and 5G dual-band) and 100M Ethernet for internet connectivity.
WiFi​
Click Settings:
android_os
In the sidebar that appears, select Network & Internet:
android_os
Select the discovered WiFi SSID and follow the prompts to enter the password to connect:
android_os
Ethernet​
Simply plug the Ethernet cable into the WalnutPi's Ethernet port. After connection, the network port indicator light will turn on.
android_os
Connecting Bluetooth Devices​
The WalnutPi Android system can connect to various Bluetooth devices such as Bluetooth keyboards, mice, Bluetooth speakers, etc.
Click Settings:
android_os
In the sidebar that appears, select Bluetooth:
android_os
Click Pair new device to search for and pair Bluetooth devices:
android_os
USB Flash Drive File Transfer​
The WalnutPi Android system supports plug-and-play USB flash drives. You can use them for copying APK installation files, photos, videos, and other files.
Insert a USB flash drive:
android_os
You will see the USB drive icon on the desktop:
android_os
You can also open it using the following method. Click: File Manager
android_os
Select the newly detected USB device:
android_os
Click to enter and you will see the files on the USB drive. The other folder contents are automatically generated when the USB drive is first inserted into the WalnutPi Android system and can be ignored.
android_os
Disabling Screen Saver​
If there is no operation for half an hour, the WalnutPi Android system will enter screen saver mode, making it impossible to operate. You can disable the screen saver using the following method.
Click Settings:
android_os
Click Device Preferences:
android_os
Click Screen saver:
android_os
Set the screen saver start time to Never.
android_os
Users can explore and test more features on their own.
