Drawing Images
The function for drawing images is similar to drawing shapes earlier - only one function is needed:
Function​
drawPixmap(x, y, width, height, QPixmap("xx.jpg"))
Draw an image.
  • x, y : Starting coordinates, top-left corner of the image;
  • width : Width. If left blank, defaults to the image width;
  • height : Height. If left blank, defaults to the image height;
  • QPixmap("xx.jpg") : Image path. Supports common formats such as BMP, JPG, JPEG, PNG;
Programming Method​
We will use code to draw an image:
Let's run the final code first, then explain it:
# pyQT5 For WalnutPi
from PyQt5.QtCore import Qt
from PyQt5.QtGui import QPainter, QPixmap
from PyQt5.QtWidgets import QWidget
class Window(QWidget):
def __init__(self):
super().__init__() # Also execute the parent QWidget's initialization
self.setWindowTitle("WalnutPi Paint") # Set window title
self.resize(480,320) # Set window size
# Window background color setting
self.setObjectName("Paint_Window")
self.setStyleSheet("#Paint_Window{background-color: black}") # Black
def paintEvent(self,event):
painter=QPainter(self) # Create drawing object
painter.setPen(Qt.green) # Set pen, green
# Draw image
painter.drawPixmap(0,0,QPixmap("linux.jpg"))
# Main Program Code #
#【Optional Code】Allow Thonny remote execution
#【Optional Code】Fix display issues on monitors with 2K+ resolution
# Program entry point: build the window and display it
window = Window() # Build window object
window.show() # Display window
#window.showFullScreen() # Fullscreen display window
#【Recommended Code】Allow terminal to interrupt window with ctrl+c for easier debugging
sys.exit(app.exec_()) # Exit process when program closes
First, place the image you want to display in the same directory as the code:
iamge1
Run the code, and you will see the following result:
iamge2
Now let's look at the implementation principle of the code:
The main program entry code is similar to before, creating a new window:
The newly created window initializes the window title and size, and also sets the background color to black for easier observation of results.
def __init__(self):
def paintEvent(self,event): is a fixed format. This function is automatically executed after the window is built, so the QPainter object initialization and drawing functions are placed inside it.
# Draw image
painter.drawPixmap(0, 0, QPixmap("linux.jpg"))
Modify the image drawing code as follows:
# Draw image
painter.drawPixmap(0, 0, 150, 100, QPixmap("linux.jpg"))
Run again, and you will see the image has been resized to 150x100:
iamge3
