PushButton
Introduction
The PushButton widget is very common; it's called a button widget with press and release effects.
PushButton1
Editing the button is simple. Double-click to modify the button text content, and drag the edges to resize the button. Font size, adding icons, and other settings can all be configured in the right-side properties panel.
PushButton2
The Python code generated from this window is as follows:
self.pushButton.setGeometry(QtCore.QRect(180, 120, 111, 41))
font = QtGui.QFont()
font.setFamily("Agency FB")
font.setPointSize(12)
self.pushButton.setFont(font)
MainWindow.setWindowTitle(_translate("MainWindow", "MainWindow"))
self.pushButton.setText(_translate("MainWindow", "Button"))
The code related to the button is as follows:
self.pushButton = QtWidgets.QPushButton(self.centralwidget) # Create a button widget in the window
self.pushButton.setGeometry(QtCore.QRect(180, 120, 111, 41)) # Button x, y, width, height
# Set button font and color
self.pushButton.setObjectName("pushButton") # Set button object name, not display name
self.pushButton.setText(_translate("MainWindow", "Button")) # Change display name to "Button"
QPushButton Object
Common MethodsDescription
setText()Set the text displayed on the button
Text()Get the text content displayed on the button
setEnabled()When parameter is False, the button is disabled
Common SignalsDescription
clickedTriggered on click
Example
Example: Program the button to execute a custom function when clicked.
The most commonly used signal for buttons is click, i.e., clicked. Use pushButton.clicked.connect() to specify the function to execute when the button is clicked.
Referring to the Signals and Slots section, add the following after self.retranslateUi(MainWindow):
self.pushButton.clicked.connect(self.fun) # Execute fun function when button is pressed
Then add the function to be executed inside the Ui_MainWindow class. Here, it prints information to the terminal:
# Function executed when button is pressed
def fun(self):
print('Button is Press!')
The complete code is as follows:
self.pushButton.clicked.connect(self.fun) # Button signal and slot definition
def fun(self):
# Main Program Code #
#【Optional Code】Allow Thonny remote execution
#【Optional Code】Fix display issues on monitors with 2K+ resolution
# Program entry point: build the window and display it
MainWindow = QtWidgets.QMainWindow() # Build window object
ui = Ui_MainWindow() # Build PyQt5-designed window object
ui.setupUi(MainWindow) # Initialize window
MainWindow.show() # Display window
#【Recommended Code】Allow terminal to interrupt window with ctrl+c for easier debugging
sys.exit(app.exec_()) # Exit process when program closes
Run the code. Each time you press the button, you will see 'Button is Press!' printed in the terminal.
PushButton3
You can also combine this with the earlier Python embedded programming to implement functions like controlling an LED with a button.
