ToolButton
Introduction
The main difference between ToolButton and PushButton is that it can have a directional arrow.
Editing the tool button is simple. Double-click to modify the button text content, and drag the edges to resize the button. All other properties can be configured in the right-side properties panel.
The Python code generated from this window is as follows:
self.toolButton = QtWidgets.QToolButton(self.centralwidget)
self.toolButton.setGeometry(QtCore.QRect(180, 130, 50, 50))
self.toolButton.setArrowType(QtCore.Qt.LeftArrow)
self.toolButton.setObjectName("toolButton")
self.toolButton_2 = QtWidgets.QToolButton(self.centralwidget)
self.toolButton_2.setGeometry(QtCore.QRect(290, 130, 50, 50))
self.toolButton_2.setArrowType(QtCore.Qt.RightArrow)
self.toolButton_2.setObjectName("toolButton_2")
MainWindow.setWindowTitle(_translate("MainWindow", "MainWindow"))
self.toolButton.setText(_translate("MainWindow", "..."))
self.toolButton_2.setText(_translate("MainWindow", "..."))
The code related to the tool buttons is as follows:
# Tool button (left arrow)
self.toolButton.setArrowType(QtCore.Qt.LeftArrow) # Left arrow
# Tool button (right arrow)
self.toolButton_2.setArrowType(QtCore.Qt.RightArrow) # Right arrow
QToolButton Object
| Common Methods | Description |
| setText() | Set the text displayed on the button |
| setArrowType() | Set arrow direction. Parameters: ● QtCore.Qt.NoArrow : None ● QtCore.Qt.UpArrow : Up ● QtCore.Qt.DownArrow : Down ● QtCore.Qt.LeftArrow : Left ● QtCore.Qt.RightArrow : Right |
| Common Signals | Description |
| clicked | Triggered on click |
Example
Example: Program two buttons to execute different functions when clicked.
The most commonly used signal for buttons is click, i.e., clicked. Use pushButton.clicked.connect() to specify the function to execute when the button is clicked.
Referring to the Signals and Slots section, add the following after self.retranslateUi(MainWindow):
self.toolButton.clicked.connect(self.fun1) # Execute fun1 function when pressed
self.toolButton_2.clicked.connect(self.fun2) # Execute fun2 function when pressed
Then add the functions to be executed inside the Ui_MainWindow class. Here, they print information to the terminal:
# Function executed when tool button 1 is pressed
def fun1(self):
print('Left')
# Function executed when tool button 2 is pressed
def fun2(self):
print('Right')
The complete code is as follows:
def fun1(self):
print('Left')
def fun2(self):
print('Right')
# Main Program Code #
#【Optional Code】Allow Thonny remote execution
#【Optional Code】Fix display issues on monitors with 2K+ resolution
# Program entry point: build the window and display it
MainWindow = QtWidgets.QMainWindow() # Build window object
ui = Ui_MainWindow() # Build PyQt5-designed window object
ui.setupUi(MainWindow) # Initialize window
MainWindow.show() # Display window
#【Recommended Code】Allow terminal to interrupt window with ctrl+c for easier debugging
sys.exit(app.exec_()) # Exit process when program closes
Run the code. Pressing the left arrow button prints "Left" and pressing the right arrow button prints "Right".
