Writing and Running Code
Local on WalnutPi​
In the previous section, we designed a UI window using Qt Designer and converted it into Python code. Since it's Python programming, we can open the Python code on the WalnutPi board and program directly.
On the WalnutPi, we recommend using Thonny to open and edit Python files. For instructions, see: Thonny IDE.
Open the window.py file generated in the previous section and add the following program entry code at the end. The complete code after adding is as follows:
# pyQT5 For WalnutPi
MainWindow.setWindowTitle(_translate("MainWindow", "WalnutPi"))
self.pushButton.setText(_translate("MainWindow", "PushButton"))
# Main Code #
# [Optional] Allow Thonny remote execution
# [Optional] Fix display issues on 2K+ resolution monitors
# Main program entry — build and display the window
MainWindow = QtWidgets.QMainWindow() # Create window object
ui = Ui_MainWindow() # Create PyQt5-designed window object
ui.setupUi(MainWindow) # Initialize window
MainWindow.show() # Show window
# [Recommended] Allow Ctrl+C to interrupt the window from terminal for easier debugging
sys.exit(app.exec_()) # Exit the process when the window is closed
Click "Run" in Thonny on the WalnutPi desktop — you'll see the first window we designed in the previous section pop up. (Terminal warnings can be ignored.)
code_run1
You can also run the modified window.py file from the terminal using the python command — the effect is the same.
code_run2
Click the close button on the window to terminate the process. For windows without a close button, you can press Ctrl+C in the terminal to interrupt the window process.
Tip
Since PyQt5 is cross-platform, the operations on Windows are exactly the same as described above.
Thonny Remote Development (Based on Windows)​
Above we used the Thonny IDE within the WalnutPi system. Similarly, we can use the Thonny IDE on Windows to remotely connect to the WalnutPi for Python programming. The WalnutPi factory system already has SSH pre-installed, allowing SSH-based remote control. This method is suitable for developing remotely from your own computer. For the remote method, refer to Python Embedded Programming: Thonny Remote. No need to repeat here.
Note that when using Thonny remotely, you must add the following code for it to work properly:
# Allow Thonny remote execution
Remotely open the WalnutPi's window.py file (the complete code above) and click Run:
code_run3
The window will pop up on the WalnutPi board's desktop.
code_run4
To exit the window program, use Run > Interrupt from the Thonny main menu or press Ctrl+C in the lower terminal.
code_run5
Displaying on a 3.5-inch LCD​
The methods above can display on either the WalnutPi HDMI monitor or the 3.5-inch LCD. For instructions on using the 3.5-inch display, see: 3.5-inch Touch Display
code_run6
Running PyQt5 Without a Desktop Environment​
For a non-desktop system, you need to enable the mouse-enabled xterm terminal to enter QT debugging mode.
sudo systemctl enable lightdm.service
After running, reboot for the changes to take effect:
After reboot, it will auto-login as pi. The command prompt is in the upper-left corner and you can see the mouse cursor, as shown below:
code_run7
At this point, you can run PyQt5 Python code locally or remotely:
code_run8
The following command exits this functionality:
sudo systemctl disable lightdm.service
Also requires a reboot to take effect, returning to normal terminal mode:
