ToolButton
Introduction​
The main difference between a ToolButton and a PushButton is that a ToolButton can include a directional arrow.
ToolButton1
Editing a ToolButton is simple — double-click to modify the button text, and drag the edges to resize it. All other properties can be configured in the property panel on the right.
ToolButton2
The generated Python code for this window is as follows:
self.toolButton = QtWidgets.QToolButton(self.centralwidget)
self.toolButton.setGeometry(QtCore.QRect(180, 130, 50, 50))
self.toolButton.setArrowType(QtCore.Qt.LeftArrow)
self.toolButton.setObjectName("toolButton")
self.toolButton_2 = QtWidgets.QToolButton(self.centralwidget)
self.toolButton_2.setGeometry(QtCore.QRect(290, 130, 50, 50))
self.toolButton_2.setArrowType(QtCore.Qt.RightArrow)
self.toolButton_2.setObjectName("toolButton_2")
MainWindow.setWindowTitle(_translate("MainWindow", "MainWindow"))
self.toolButton.setText(_translate("MainWindow", "..."))
self.toolButton_2.setText(_translate("MainWindow", "..."))
The code related to the ToolButton is as follows:
# ToolButton (left arrow)
self.toolButton.setArrowType(QtCore.Qt.LeftArrow) # Left arrow
# ToolButton (right arrow)
self.toolButton_2.setArrowType(QtCore.Qt.RightArrow) # Right arrow
QToolButton Object​
Common MethodsDescription
setText()Set the text displayed on the button
setArrowType()Set arrow direction. Parameters:
● QtCore.Qt.NoArrow : None
● QtCore.Qt.UpArrow : Up
● QtCore.Qt.DownArrow : Down
● QtCore.Qt.LeftArrow : Left
● QtCore.Qt.RightArrow : Right
Common SignalsDescription
clickedTriggered on click
Example​
Example: Programmatically make clicking two buttons execute different functions.
The most commonly used button signal is click, i.e., clicked. Use pushButton.clicked.connect() to specify the function to execute when the button is clicked.
Referring to the signals and slots section, add the following after self.retranslateUi(MainWindow):
self.toolButton.clicked.connect(self.fun1) # Execute fun1 when pressed
self.toolButton_2.clicked.connect(self.fun2) # Execute fun2 when pressed
Then add the functions to execute inside the Ui_MainWindow class — here we'll have them print messages to the terminal:
# Function executed when ToolButton 1 is pressed
def fun1(self):
print('Left')
# Function executed when ToolButton 2 is pressed
def fun2(self):
print('Right')
Here's the complete code:
def fun1(self):
print('Left')
def fun2(self):
print('Right')
# Main Code #
# [Optional] Allow Thonny remote execution
# [Optional] Fix display issues on 2K+ resolution monitors
# Main program entry — build and display the window
MainWindow = QtWidgets.QMainWindow() # Create window object
ui = Ui_MainWindow() # Create PyQt5-designed window object
ui.setupUi(MainWindow) # Initialize window
MainWindow.show() # Show window
# [Recommended] Allow Ctrl+C to interrupt the window from terminal for easier debugging
sys.exit(app.exec_()) # Exit the process when the window is closed
Run the code. Pressing the left arrow button prints "Left", and pressing the right arrow button prints "Right".
ToolButton3
