Adding Commercial Products
Xiaomi Temperature and Humidity Sensor
Below are several commercially available Xiaomi temperature and humidity sensors.
xiaomi
These types of temperature/humidity sensors broadcast information such as temperature, humidity, and battery level via Bluetooth broadcasting without requiring a connection. They can be directly discovered by the WalnutPi Home Assistant host.
Bring the Xiaomi temperature/humidity sensor close to the WalnutPi Home Assistant host:
xiaomi
Click Configuration -- Add Integration, and search for xiaomi in the popup window:
xiaomi
Select Xiaomi BLE:
xiaomi
You can see that a device has appeared — click Submit.
xiaomi
The Xiaomi BLE integration now appears in the integrations list.
xiaomi
Click into it to see the associated devices and entities, then click Devices to view the data information:
xiaomi
xiaomi
It can be added to the homepage dashboard:
xiaomi
xiaomi
