Automations
In the previous sections we added many devices and entities. The Automation feature covered in this section is what enables coordination between these devices, entities, and events.
An automation consists of three key components:
  1. Triggers — Events that start an automation. For example, when the sun sets or a motion sensor is activated.
  2. Conditions — Optional tests that must pass before an action can run. For example, if someone is home.
  3. Actions — Interactions with devices. For example, turning on a light.
Button and LED​
In the MQTT integration, we added LED and button entities, both controlled through the Home Assistant interface. Here we will create an automation so that pressing the button on the WalnutPi 2B board toggles the LED on and off, as a way to learn how to use Home Assistant automations.
For adding LED and button entities, refer to the tutorials: LED and Button. We won't repeat them here.
Copy the LED and button code from the examples above to your WalnutPi 2B board. You can run both scripts simultaneously in the terminal with the following command to register the entities in Home Assistant:
sudo python led.py & sudo python key.py
automation
For more ways to run Python scripts, see: Running Python Code
After running the code successfully, open the Home Assistant MQTT device — you will see 2 new entities:
automation
Now let's start setting up the automation. Click Settings → Automations & Scenes:
automation
Then click Create Automation at the bottom right:
automation
Click Create new automation:
automation
Click Add Trigger and select Other trigger: (Because the Home Assistant device trigger does not support button devices, we can use MQTT messages as the trigger.)
automation
Search for "mqtt", then click + to add:
automation
In the popup window, enter the MQTT topic and payload. From the Button experiment, we know the topic and payload published when the WalnutPi 2B button is pressed:
automation
MQTT Topic:
1b_key/event/state
MQTT Payload:
{"event_type":"press"}
Fill in the above topic and payload in the trigger:
automation
In the Then do section below, click Add Action and select Light:
automation
Select Toggle, meaning each button press toggles the LED on/off:
automation
Then click + Choose Entity:
automation
The LED entity is automatically recognized — click to select it:
automation
Click Save at the bottom right:
automation
In the popup, enter a name for this automation. The content can be whatever you like:
automation
Returning to the automation main page, you can see the newly created "Automation" has been added:
automation
Press the KEY button on the WalnutPi 2B. You will see the blue LED toggles on and off — the light-switching automation is working:
automation
