Camera Monitoring
Home Assistant integrates the MJPEG IP Camera integration, which can work with the WalnutPi USB camera setup from earlier to enable monitoring through the Home Assistant interface.
ip_camera
For the WalnutPi USB camera tutorial, see the previous USB Camera section. We won't repeat it here.
After following the tutorial above to start the camera and verify it works, proceed to add the device in Home Assistant:
Open Settings → Add Integration:
ip_camera
In the popup, search for the keyword MJPEG, then select MJPEG IP Camera below:
ip_camera
Next, fill in the camera information:
ip_camera
Once completed, you'll see MJPEG IP Camera added under Integrations:
ip_camera
Open the device and click the small circle below to view the camera feed:
ip_camera
ip_camera
It can be added to the Overview dashboard:
ip_camera
ip_camera
After adding, you may notice the dashboard monitoring feed does not refresh in real time. Configure it as follows:
Click the small pencil button in the top right corner to enter card editing mode:
ip_camera
Click Edit at the bottom left of the monitoring card:
ip_camera
Set Camera View to: Live:
ip_camera
After saving and going back, refresh the webpage, and you'll see the camera feed updating in real time:
ip_camera
