Adding Commercial Products
Xiaomi Temperature/Humidity Sensor
Here are a few commercially available Xiaomi temperature/humidity sensors.
These sensors broadcast temperature, humidity, battery level, and other information via Bluetooth advertising without requiring a connection. They can be directly discovered by the WalnutPi Home Assistant host.
Place the Xiaomi temperature/humidity sensor close to the WalnutPi Home Assistant host:
Click Settings → Add Integration, and search for xiaomi in the popup:
Select Xiaomi BLE:
A device will appear — click Submit.
You can now see the Xiaomi BLE integration under Integrations.
Click in to see the relevant device and entities, then click Device to view the data:
It can be added to the Overview dashboard:
