Initial Configuration
Network Connection​
After installation, power the WalnutPi with a 5V supply and connect it to your router via Ethernet or WiFi.
config
Via Ethernet​
Connect one end of the Ethernet cable to the WalnutPi board and the other end to your router.
config
Via WiFi​
For WalnutPi WiFi connection instructions, see: WiFi Connection
Mobile App Download (Optional)​
Home Assistant provides an official app that works the same as the PC browser. Installation methods:
iPhone​
Search for "Home Assistant" in the App Store and install:
config
Android Phone​
Download the APK to install. The APK can be found in the WalnutPi Home Assistant resource package — APP folder:
config
Initial Setup​
Open the Configuration Page​
The Home Assistant host takes about 2-3 minutes to fully start up. Once started and connected to the network, you can initialize Home Assistant via a mobile phone or computer browser:
After the WalnutPi boots, the blue LED will blink, indicating that Home Assistant is starting. Once Home Assistant is fully started, the LED stays solid on, meaning it is ready for the following configuration steps.
  • From Mobile Phone
The benefit of using the app is that it can automatically discover the Home Assistant host on the local network when both the phone and Home Assistant are connected to the same router. Open the app and it will be found:
config
  • From Browser
Enter http://walnutpi.local:8123 in your computer browser or WalnutPi browser (Desktop edition) to access the initialization page.
(If this link does not work, use: http://XXXX:8123, where XXXX is the current IP address of your WalnutPi, e.g., http://192.168.1.100:8123) How to Get WalnutPi IP Address
After configuration, we recommend logging in using the IP address. http://walnutpi.local:8123 sometimes fails to open in practice.
Start Configuration​
You will see the following welcome screen:
config
Select your language in the bottom left, then click the Create My Smart Home button.
config
Enter your custom name, username, and password (please remember your credentials), then click Create Account:
config
Enter your geographic location. Users without proxy/VPN may not see the map — you can simply click Next to skip this step:
config
Select your region:
config
Choose whether to share usage data with the official team:
config
The system prompts that some devices were discovered — click Finish.
config
You will then enter the main interface. After this initial setup, logging in will always bring you to this dashboard page. The devices discovered earlier may appear on the dashboard:
config
Fix Warnings​
The warning System unhealthy - not privileged appears because this is the first boot from the image. Click Ignore. Note that after ignoring, you need to restart the host, otherwise online updates and some add-on installations will not work.
Restart Methods:
  1. Execute sudo reboot in the WalnutPi terminal to restart.
  2. Press and hold the button for more than 6 seconds to shut down, then power off and on again to restart.
Directly cutting power is not recommended, as unsaved content may be lost.
config
The warning Unsupported system - CGroup version can be ignored directly:
config
System Update​
When a Home Assistant update is available, you can click to enter and update directly. For users without proxy/VPN access, the update may take quite a while (10+ minutes). Please be patient.
config
Network Management​
Network management is used to manage wired and wireless (WiFi) connections of the Home Assistant host.
Click Settings → System:
config
Click Network:
config
Here you can see the network status of wired Ethernet (ETH0) and wireless WiFi (WLAN0), including IP addresses, as well as scan for WiFi hotspots and connect, and other settings.
config
To connect to a WiFi hotspot, enable both IPv4 and IPv6 for WLAN0, then scan, select the hotspot, enter the password, and connect. Once connected, you can see the IP information.
config
When switching network methods, the IP address will change. Remember to update the login address for the Home Assistant host accordingly.
Safe Shutdown​
Press and hold the WalnutPi button for more than 6 seconds. The LED will blink a few times, then you can release. The shutdown process will begin. Wait until the blue LED turns off, indicating that shutdown is complete.
Warning
Do not directly cut power to turn off the WalnutPi, as this may cause Home Assistant data errors or loss.
