WiFi Connection
  • Video Tutorial
Once the system is running, the first thing you'll probably want to do is connect to the internet. For Ethernet, simply plug in an Ethernet cable. Additionally, the Walnut Pi has an onboard dual-band WiFi module supporting both 2.4G and 5G WiFi networks.
Connecting via Desktop Button​
On the Desktop edition, simply click the network icon in the bottom-right corner, select Available Networks, choose your WiFi network, and enter the password to connect.
wifi1
Connecting via Command Line (Server Edition)​
Connecting to WiFi via command line is suitable for the Server edition or for scenarios where you only access the system through the terminal. Here's how:
First, use the following command to get the list of available WiFi SSIDs:
nmcli dev wifi
wifi2
Warning
You must first run the nmcli dev wifi command above to obtain WiFi information before proceeding with the connection.
Press Ctrl+C or Ctrl+Z to interrupt the above command.
Next, use the following command to connect to a specific WiFi network (sudo root privileges are required). In the example below, "walnutpi" is the WiFi SSID and "88888888" is the password. Replace these with your own WiFi credentials.
sudo nmcli dev wifi connect walnutpi password 12345678
After a successful connection, you can use the following command to check the WiFi connection status. The presence of an IP address indicates a successful connection.
sudo ifconfig
wlan0 indicates the WiFi connection with an IP address shown below it, while eth0 indicates the Ethernet connection.
wifi3
