USB Drive Mounting
Insert the USB drive into one of the Walnut Pi's USB ports.
usb_disk1
Desktop Edition​
The Desktop edition behaves similarly to a Windows PC: after inserting a USB drive, a semi-transparent USB drive icon will appear on the desktop.
usb_disk2
Simply double-click the icon to mount and open the USB drive. You will see that the USB drive is located under the /media/pi/ directory:
usb_disk3
Server Edition (Headless)​
On the Server edition, you can use commands to mount the USB drive. (This method also works on the Desktop edition)
After inserting the USB drive, first check its information:
sudo fdisk -l
usb_disk4
In this example, a 4GB USB drive is used. From the image above, you can see the device is: /dev/sda1.
Once you know the USB drive's device name, you can mount it using the mount command, typically to the /media or /mnt directory:
First, create an empty folder under /media. You can name it anything you like; here we'll use "udisk":
sudo mkdir udisk
Mount the USB drive:
sudo mount /dev/sda1 /media/udisk
Once mounted successfully, use the "ls" command to view the contents of the USB drive, confirming it is mounted successfully.
ls /media/udisk
usb_disk5
You can unmount the USB drive with the following command:
sudo umount /media/udisk
