YOLO11 Detection
This model finds all annotated object types in an image.
result
Prepare Model File​
The program package we provide includes a file named yolo11n.nb, which is the model file for running YOLO11 detection on the WalnutPi 2B (T527) NPU.
result
If you want to try converting the model yourself, refer to: Model Conversion Tutorial
Install OpenCV​
This tutorial requires the OpenCV library. For installation instructions, refer to: OpenCV Installation
Run Model with Python​
WalnutPi 2B v1.3.0 and above provides a packaged YOLO11 Python library.
1. Instantiate yolo11 Class​
Instantiate the YOLO11_DET class by passing the model file path:
yolo = YOLO11.YOLO11_DET("model/yolo11n.nb")
2. Run Model - Blocking Mode​
Use the run method to run the model and get detection results. It takes 3 parameters:
  • Image data, read using OpenCV's image reading method
  • Confidence threshold, only detection boxes above this confidence will be returned
  • Detection box overlap threshold, the model often hits multiple boxes around an object. If the area overlap between boxes exceeds this value, only the box with the highest confidence is kept, and other overlapping boxes are removed
# Read image
img = cv2.imread("image/dog.jpg")
# Detect
boxes = yolo.run(img, 0.5, 0.45)
3. Run Model - Non-blocking Mode​
Use the run_async method, which creates a thread to run the model and returns immediately. It takes 3 parameters:
Non-blocking mode works with the is_running property, which has a value of true or false, indicating whether a run_async model thread is running in the background. If a thread is already running, calling run_async again won't start a new thread. You can also use this property to check if the model thread has finished and results are ready.
Use the get_result() method to return the background recognition result, which is the same as what the blocking run method returns:
yolo.run_async(img, 0.5, 0.45)
4. Detection Results​
Both the run method and get_result method return a list. If nothing is detected in the image, an empty list is returned. Each value in the list represents a detected box, and each box object contains the following properties:
PropertyDescription
xx-coordinate of the detection box center
yy-coordinate of the detection box center
wWidth of the detection box
hHeight of the detection box
reliabilityConfidence of the detection box, e.g., 0.78
labelLabel of the detection box
Note that label is a number. For example, the official YOLO model was trained with 80 annotated types, so the detected label property will be 0-79.
The following code can be used to output all detected box information:
"{:f} ({:4d},{:4d}) w{:4d} h{:4d} {:d}".format(
Example Programs​
Image-Based​
results
Experiment Name: YOLO11 Detection
Experiment Platform: WalnutPi 2B
Description: Image detection
import dataset_coco
# [Optional] Allow Thonny remote execution
path_model = "model/yolo11n.nb" # Model path
path_image = "image/bus.jpg" # Image path
output_path = "result.jpg" # Output result save path
# Read image
img = cv2.imread(path_image)
# Detect image
yolo = YOLO11.YOLO11_DET(path_model)
# Perform object detection with confidence threshold of 0.5 and IoU threshold of 0.45
# Output detection results
"{:f} ({:4d},{:4d}) w{:4d} h{:4d} {:s}".format(
dataset_coco.label_names[box.label],
# Draw boxes on image
label = str(dataset_coco.label_names[box.label]) + " " + str(box.reliability)
(left_x, left_y),
(right_x, right_y),
(255, 255, 0),
2,
# Save image
# Display image in window
cv2.waitKey() # Wait for any key press
cv2.destroyAllWindows() # Close window
Camera-Based​
You can first learn about the USB Camera Usage Tutorial in OpenCV.
results
Description: Camera capture detection
import dataset_coco
import cv2,time
# Load model
# Open camera
# Set to 1080p
# cap.set(cv2.CAP_PROP_FOURCC, cv2.VideoWriter_fourcc(*"MJPG"))
# cap.set(cv2.CAP_PROP_FRAME_WIDTH, 1920) # Set width
# cap.set(cv2.CAP_PROP_FRAME_HEIGHT, 1080) # Set height
boxes = []
# Calculate FPS
count=0
pt=0
fps = 0
# Calculate FPS
count+=1
if time.time()-pt >=1 : # Over 1 second
fps=1/((time.time()-pt)/count)# Calculate FPS
print(fps)
count=0
pt=time.time()
# Read a frame from camera
# Non-blocking image inference
if boxes is not None:
label = str(dataset_coco.label_names[box.label]) + " " + str('%.2f'%box.reliability)
(left_x, left_y),
(right_x, right_y),
(255, 255, 0),
2,
cv2.putText(img, 'FPS: '+str(fps), (10,30), cv2.FONT_HERSHEY_SIMPLEX, 1, (0,0,255), 2) # Draw FPS on image
cv2.imshow("result", img)# Display image in window
key = cv2.waitKey(1) # Window refresh interval of 1ms to prevent blocking
if key == 32: # Press space key to exit
cap .release() # Release camera
cv2.destroyAllWindows() # Destroy camera video window
