YOLO11 Pose Estimation
This model identifies poses, outputting coordinates of keypoints such as nose, eyes, ears, shoulders, hands, and legs. These coordinates can be used to determine postures. You can also train it to recognize poses of other animals.
model_change
Prepare Model File​
The program package we provide includes a file named yolo11n-pose.nb, which is the model file for running YOLO11 pose estimation on the WalnutPi 2B (T527) NPU.
result
If you want to try converting the model yourself, refer to: Model Conversion Tutorial
Install OpenCV​
This tutorial requires the OpenCV library. For installation instructions, refer to: OpenCV Installation
Run Model with Python​
WalnutPi 2B v1.3.0 and above provides a packaged YOLO11 Python library.
1. Instantiate yolo11 Class​
Instantiate the YOLO11_POSE class by passing the model file path:
yolo = YOLO11.YOLO11_POSE("model/yolo11n-pose.nb")
2. Run Model - Blocking Mode​
Use the run method to run the model and get detection results. It takes 3 parameters:
  • Image data, read using OpenCV's image reading method
  • Confidence threshold, only detection boxes above this confidence will be returned
  • Detection box overlap threshold, the model often hits multiple boxes around an object. If the area overlap between boxes exceeds this value, only the box with the highest confidence is kept, and other overlapping boxes are removed
# Read image
img = cv2.imread("image/bus.jpg")
# Detect
boxes = yolo.run(img, 0.5, 0.5)
3. Run Model - Non-blocking Mode​
Use the run_async method, which creates a thread to run the model and returns immediately. It takes 3 parameters:
Non-blocking mode works with the is_running property, which has a value of true or false, indicating whether a run_async model thread is running in the background. If a thread is already running, calling run_async again won't start a new thread. You can also use this property to check if the model thread has finished and results are ready.
Use the get_result() method to return the background recognition result, which is the same as what the blocking run method returns:
yolo.run_async(img, 0.5, 0.5)
4. Detection Results​
Both the run method and get_result method return a list. If nothing is detected in the image, an empty list is returned. Each value in the list represents a detected box, and each box object contains the following properties:
PropertyDescription
xx-coordinate of the detection box center
yy-coordinate of the detection box center
wWidth of the detection box
hHeight of the detection box
reliabilityConfidence of the detection box, e.g., 0.78
labelLabel of the detection box; generally pose models only recognize 1 type
keypointsInformation about each keypoint
The keypoints property is a list, where each value is a keypoint object. For example, using the official YOLO human pose model, there are 17 keypoints in the following order:
Keypoint IndexKeypoint Name
0Nose
1Left Eye
2Right Eye
3Left Ear
4Right Ear
5Left Shoulder
6Right Shoulder
7Left Elbow
8Right Elbow
9Left Wrist
10Right Wrist
11Left Hip
12Right Hip
13Left Knee
14Right Knee
15Left Ankle
16Right Ankle
Each keypoint object contains the following properties:
PropertyDescription
xyKeypoint xy coordinates, e.g., (192,320)
visibilityProbability that the point is visible
The following code can be used to output all detected box information:
"{:f} ({:4d},{:4d}) w{:4d} h{:4d} lbael:{:d}".format(
Example Programs​
Image-Based​
Read an image for detection and draw the detected keypoints.
results
Experiment Name: YOLO11 Pose Estimation
Experiment Platform: WalnutPi 2B
Description: Image-based
# [Optional] Allow Thonny remote execution
label_names = ["person"]
model_path = "model/yolo11n-pose.nb"
picture_path = "image/person.jpg"
output_path = ".result.jpg"
# Detect image
yolo = YOLO11.YOLO11_POSE(model_path)
boxes = yolo.run(picture_path, 0.5, 0.5)
# Draw boxes on image
img = cv2.imread(picture_path)
label = str(label_names[box.label]) + " " + str('%.2f'%(box.reliability))
(left_x, left_y),
(right_x, right_y),
(255, 255, 0),
2,
# 0 Nose 1 Left Eye 2 Right Eye 3 Left Ear 4 Right Ear 5 Left Shoulder 6 Right Shoulder
# 7 Left Elbow 8 Right Elbow 9 Left Wrist 10 Right Wrist 11 Left Hip 12 Right Hip
# 13 Left Knee 14 Right Knee 15 Left Ankle 16 Right Ankle
for i in box.keypoints: # Draw all keypoints with high enough visibility
if i.visibility > 0.5:
cv2.circle(img, i.xy, 5, (0, 0, 200), -1)
# Head connections
cv2.line(img, box.keypoints[3].xy, box.keypoints[1].xy, (0, 255, 255), 2)
cv2.line(img, box.keypoints[1].xy, box.keypoints[0].xy, (0, 255, 255), 2)
cv2.line(img, box.keypoints[0].xy, box.keypoints[2].xy, (0, 255, 255), 2)
cv2.line(img, box.keypoints[2].xy, box.keypoints[4].xy, (0, 255, 255), 2)
cv2.line(img, box.keypoints[3].xy, box.keypoints[5].xy, (0, 255, 255), 2)
cv2.line(img, box.keypoints[4].xy, box.keypoints[6].xy, (0, 255, 255), 2)
# Left and right arm connections
cv2.line(img, box.keypoints[7].xy, box.keypoints[5].xy, (255, 0, 0), 2)
cv2.line(img, box.keypoints[7].xy, box.keypoints[9].xy, (255, 0, 0), 2)
cv2.line(img, box.keypoints[8].xy, box.keypoints[6].xy, (255, 0, 0), 2)
cv2.line(img, box.keypoints[8].xy, box.keypoints[10].xy, (255, 0, 0), 2)
# Torso connections
cv2.line(img, box.keypoints[5].xy, box.keypoints[6].xy, (100, 255, 100), 2)
cv2.line(img, box.keypoints[11].xy, box.keypoints[5].xy, (100, 255, 100), 2)
cv2.line(img, box.keypoints[12].xy, box.keypoints[6].xy, (100, 255, 100), 2)
cv2.line(img, box.keypoints[12].xy, box.keypoints[11].xy, (100, 255, 100), 2)
# Left and right leg connections
cv2.line(img, box.keypoints[13].xy, box.keypoints[11].xy, (255, 255, 0), 2)
cv2.line(img, box.keypoints[13].xy, box.keypoints[15].xy, (255, 255, 0), 2)
cv2.line(img, box.keypoints[14].xy, box.keypoints[12].xy, (255, 255, 0), 2)
cv2.line(img, box.keypoints[14].xy, box.keypoints[16].xy, (255, 255, 0), 2)
# Save image
# Display image in window
cv2.waitKey()
cv2.destroyAllWindows()
Camera-Based​
You can first learn about the USB Camera Usage Tutorial in OpenCV.
results
Description: Camera-based
# Open camera and loop to get frames and display on screen
boxes = []
yolo.run_async(img, 0.3)
label = str(label_names[box.label]) + " " + str('%.2f'%box.reliability)
label, cv2.FONT_HERSHEY_SIMPLEX, 0.5, 1,
cv2.rectangle(img, (left_x, left_y), (right_x, right_y), (255, 255, 0), 2)
cv2.rectangle(img, (left_x, left_y - label_height * 2), (left_x + label_width, left_y), (255, 255, 255), -1)
cv2.putText(img, label, (left_x, left_y - label_height), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 0, 0), 1)
# Head connections
# Torso connections
cv2.imshow("result", img)
key = cv2.waitKey(1)
if key == 32:
cap.release()
