YOLO11 Image Segmentation
This model builds upon the detection model by adding the ability to determine which pixels belong to the target object.
result
Prepare Model File​
The program package we provide includes a file named yolo11n-seg.nb, which is the model file for running YOLO11 image segmentation on the WalnutPi 2B (T527) NPU.
result
If you want to try converting the model yourself, refer to: Model Conversion Tutorial
Install OpenCV​
This tutorial requires the OpenCV library. For installation instructions, refer to: OpenCV Installation
Run Model with Python​
WalnutPi 2B v1.3.0 and above provides a packaged YOLO11 Python library.
1. Instantiate yolo11 Class​
Instantiate the YOLO11_SEG class by passing the model file path:
yolo = YOLO11.YOLO11_SEG("model/yolo11n-seg.nb")
2. Run Model - Blocking Mode​
Use the run method to run the model and get detection results. It takes 3 parameters:
  • Image data, read using OpenCV's image reading method
  • Confidence threshold, only detection boxes above this confidence will be returned
  • Detection box overlap threshold, the model often hits multiple boxes around an object. If the area overlap between boxes exceeds this value, only the box with the highest confidence is kept, and other overlapping boxes are removed
# Read image
img = cv2.imread("image/bus.jpg")
# Detect
boxes = yolo.run(img, 0.5, 0.5)
3. Run Model - Non-blocking Mode​
Use the run_async method, which creates a thread to run the model and returns immediately. It takes 3 parameters:
Non-blocking mode works with the is_running property, which has a value of true or false, indicating whether a run_async model thread is running in the background. If a thread is already running, calling run_async again won't start a new thread. You can also use this property to check if the model thread has finished and results are ready.
Use the get_result() method to return the background recognition result, which is the same as what the blocking run method returns:
yolo.run_async(img, 0.5, 0.5)
4. Detection Results​
Both the run method and get_result method return a list. If nothing is detected in the image, an empty list is returned. Each value in the list represents a detected box, and each box object contains the following properties:
PropertyDescription
xx-coordinate of the detection box center
yy-coordinate of the detection box center
wWidth of the detection box
hHeight of the detection box
reliabilityConfidence of the detection box, e.g., 0.78
labelLabel of the detection box
contoursList of all contour point coordinates
maskA single-channel grayscale image; pixels not belonging to the object are 0, pixels belonging to the object are 255
Note that label is a number. For example, the official YOLO model was trained with 80 annotated types, so the detected label property will be 0-79.
The following code can be used to output all detected box information:
"{:f} ({:4d},{:4d}) w{:4d} h{:4d} lbael:{:d}".format(
The mask image can be overlaid on the original image using the following code:
import numpy as np
mask_img = np.zeros_like(img) # Generate a pure black image of the same size as the original
mask_img[box.mask > 200] = (0, 255, 0) # Change pixels with mask value greater than 200 to green
img = cv2.addWeighted(img, 1, mask_img, 0.5, 0) # Overlay mask_img on the original
Example Programs​
Image-Based​
Read an image for detection and highlight target objects.
results
Experiment Name: YOLO11 Image Segmentation
Experiment Platform: WalnutPi 2B
Description: Image-based
import dataset_coco
import numpy as np
# [Optional] Allow Thonny remote execution
model_path = "model/yolo11n-seg.nb"
picture_path = "image/000000371552.jpg"
output_path = "result.jpg"
# Detect image
yolo = YOLO11.YOLO11_SEG(model_path)
boxes = yolo.run(picture_path, 0.5, 0.5)
# Draw boxes on image
img = cv2.imread(picture_path)
label = str(dataset_coco.label_names[box.label]) + " " + str('%.2f'%box.reliability)
(left_x, left_y),
(right_x, right_y),
(255, 255, 0),
2,
# Save image
# Display image in window
cv2.waitKey()
cv2.destroyAllWindows()
Camera-Based​
You can first learn about the USB Camera Usage Tutorial in OpenCV.
results
Description: Camera-based
import dataset_coco
import numpy as np
# Detect image
# Open camera and loop to display frames on screen
label, cv2.FONT_HERSHEY_SIMPLEX, 0.5, 1,
cv2.rectangle(img, (left_x, left_y), (right_x, right_y), (255, 255, 0), 2)
cv2.rectangle(img, (left_x, left_y - label_height * 2), (left_x + label_width, left_y), (255, 255, 255), -1)
cv2.putText(img, label, (left_x, left_y - label_height), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 0, 0), 1)
mask_img[box.mask > 200] = (0, 0, 255)
img = cv2.addWeighted(img, 1, mask_img, 0.8, 0)
cv2.imshow("result", img)
key = cv2.waitKey(1)
if key == 32:
cap.release()
