Obtaining IP Address
WiFi IP Address​
WiFi module hardware location. Connect wirelessly to a router via WiFi (supports 2.4G and 5G signals):
ip_get1
Use the following command to get all network IP addresses of the WalnutPi. wlan0 is the WiFi card name. Once connected, you can see its IP address.
sudo ifconfig
ip_get2
Ethernet IP Address​
Ethernet module hardware location. Connect to a router via an Ethernet cable:
ip_get3
Use the following command to get all network IP addresses of the WalnutPi. eth0 is the Ethernet card name. Once connected, you can see its IP address.
sudo ifconfig
ip_get4
