Device Map
This feature is only available in WalnutPi Gen 1 images V2.5.0 and above.
The WalnutPi Device Map is a unique feature of the WalnutPi system. It obtains the board's location via IP address and displays it on a map, with location accuracy to the city level. Device Map Link
map_device
This feature is enabled by default. Users can disable it manually:
Disable command:
systemctl disable map_device.service
Restart the board for the change to take effect.
Enable command:
systemctl enable map_device.service
